Hi all ... newbie to the spa world. I just got and installed my smarter spa this week. I'm wondering if there is something wrong with my unit since when I power it on, the only light that flashes once every 10 seconds or so, is the light to the left of "Control Flashes". If I pull the unit out of the water while in this "flashing" mode nothing happens. But if I hit the "Boost" button, I see the chlorinator start and the "Salt OK" flashes blue. If I pull out the sensor in this mode I do get a "Salt Low" indicator.
Per the manual on Power On the following should happen.
"To turn on the SmarterSpa plug in the power supply (wall transformer). When the SmarterSpa turns on it will flash the lights as follows: 1. WHITE - Blinks the software version (current - 5) 2. WHITE, RED, BLUE, GREEN - will flash in that order 3. Chlorine production may start within a few minutes depending on the chlorine level. Typically the GREEN LED will flash at the 10 second rate indicating standby mode until the unit determines that the chlorine level is low enough to start a chlorine production cycle"
I don't see this. Here is a link to a video of what I see.
VIDEO
I've reached out to support but have yet to get a reply. Any help would be greatly appreciated.
VIDEO
