Our pool has been out of commission all season with no equipment attached due to a renovation project, so excuse the algae infested water!
As part of the renovation, we're replacing the pool deck. I took the opportunity with the old pool deck removed to pressure test the lines and make sure everything else looks good before covering it all up with a new deck. One thing I'm unclear on is how to tell whether the pool light (old 120v Pentair) is properly bonded, or what to do about it if not.
The pics show the inside of the niche, where there's the main electrical line running in conduit to a J-box about 8 feet away. Then there's a separate wire sticking out of some caulk-like substance that I'm guessing is a bonding wire? It appears to be covered in white rubbery insulation rather than being a bare wire, but the white color may just be from fading over time? It's not attached to anything though, unless it was attached to the back of the light and came loose when I pulled the light out. I didn't feel any tension though.
Then outside the pool, on the back side of the light, there's a bare copper wire sticking out from inside the concrete shell next to where the light's conduit enters the concrete. That wire is currently only a few feet long and not attached to anything, but I'm assuming that's because it was cut when the contractor removed all the old concrete pool deck. That's easy enough to tie back in to the bonding grid.
The new pool deck work is starting Monday, so I'm in a bit of a rush to figure out what, if anything, I need to do here before all this stuff gets covered up again, and the light is the thing I'm most unsure about. Does this look appropriate? If not, what are my options for how to deal with it?
Thanks!
Thanks!
