- Jun 5, 2011
- 1,181
- Plaster
- Jandy Aquapure 1400
I can’t figure out what is making my water cloudy. A couple of months ago when cleaning my filter, I noticed the fabric was torn on the flex air relief assembly on the manifold. After cleaning, when starting the pool back up, the water clouded up with DE (I assume) especially in the spa. Thinking I had a DE leak due to the torn fabric, I replaced the flex air relief assembly. The water still seemed a little cloudy, but not as bad as it had been but also not as clear as it had been earlier in the year. My filter grids are 13 years old, so I decided to replace them 2 days ago. Upon inspection, the old grids didn’t have any tears that I could see. I thoroughly checked the manifold to make sure it had no cracks, which it didn’t. Upon starting the pump and before I had put new DE in, a cloud came through the line, again mostly noticeable in the spa. I assume it’s more noticeable in the spa because of the limited space and because there is a large return in it that was a fountain before I removed it to help reduce pH rise. The pool and spa both run off the same pump. After a couple of days, water has cleared up some, but is still a little cloudy. It’s really visible at night with the lights on - lots of “dust” floating in the water.
Given that I’ve replaced all grids and the flex air relief assembly, and the manifold is in good shape, what else might cause a DE leak, assuming that’s my problem? I’ve never had the big cloud of debris immediately followed a filter cleaning until these last 2 times. Any suggestions on what might cause that, especially when it happens even before adding DE?
My water chemistry has been great all year. Current test results are:
FC - 5
CYA - 70
pH - 7.6
TA - 70
CH - 300
Salt - 3400
I’ll run an OCLT tonight to verify that the “dust” isn’t algae, but my salt cell has remained at 30% most of the summer and FC levels have remained consistent.
Thanks for any suggestions.
FC - 5
CYA - 70
pH - 7.6
TA - 70
CH - 300
Salt - 3400
