So after few weeks of full pool on well water just using chlorine my pool is crystal clear. I run the pump few hours a day I never tested the water just assumed clear was best you can ask for.
Am I wrong?
Am I wrong?
Your water can be clear bit if your chlorine level drops too low, it won't be clear for too long. And the chlorine keeps the water sanitized for those who swim in it.So after few weeks of full pool on well water just using chlorine my pool is crystal clear. I run the pump few hours a day I never tested the water just assumed clear was best you can ask for.
Am I wrong?
Yes, you are very wrong.So after few weeks of full pool on well water just using chlorine my pool is crystal clear. I run the pump few hours a day I never tested the water just assumed clear was best you can ask for.
Am I wrong?
You need a good test kit to get a good set of results. I use the Taylor K2006. It's hard to give good advice with a full set of results.
This should have been Taylor2006You need a good test kit to get a good set of results. I use the Taylor K6000. It's hard to give good advice with a full set of results.
Thanks for the advice.
