I have a small 3000 gal fiberglass above ground pool that currently has a Rainbow feeder. I have been told that the pool is too small to use a chlorine generator. Can I convert?
Thank you
Thank you
I have a single speed pump.We always suggest one that’s rated for at least 2x’s your pool’s volume- in the southern US bigger is usually better. A 15k or 20k gal rated unit would be a good fit.
Do you have a variable speed, 2 speed, or single speed pump?
I guess I misread- I thought it said 6k gal pool in your original post.With a 3,000 gal. pool, either a 15k or 20k gal rated unit would be rated more than the pool. Any experience about which brand has the best units that will last the longest? In today's word, you can buy a piece of equipment which will break in a couple of years. I would rather pay more and buy a unit which will last.
Thank you for your replies.
They really aren’t bad units for the price now that prices are back to normalish.If cost is a concern Intex has a decent product. It’s not adjustable and has a tendency to corrode on internal connections. There’s an actual repairs/fix on this site that works. It would be best to use it as preventative maintenance during the off season.
Mine went belly up this year after two seasons. I purchased another and planned to use the inoperable one for parts. I then found the information here and fixed the old one. Still holding on to it just in case.
