This is for a well pump that runs my sprinklers and a couple of outside faucets but I figured why not ask this forum since the responses are always fast and thorough and for the most part a pump is a pump - right?? ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have a Grundfos JP-7 pump hooked to a AO Smith 3/4 hp single phase motor wired for 220 (model C48K2DB11A16). When I went to start it up this spring it just hummed so I replaced the capacitor but that didn't fix it. I then pulled the motor from the pump and turned the impeller a couple of times by hand to break it free. That seemed to work as it then started but after a month or so it started making a sound like it had bad bearings. So I disassembled the motor and the front bearing was shot. I replaced both bearings with Timken bearings and replaced the pump seal with one from Amazon. I reinstalled everything and it just hummed, didn't run. I pulled it off the pump housing and checked everything and then bench tested the motor. The motor runs fine not connected to the impeller but when I put the impeller back on it seems to tighten down so much that it compresses the pump seal and ruins the seal. The order of assembly for this on the pump end is as follows:
I've tried 3 different capacitors and 2 different shaft seals (same specs, just different mfrs) with no luck. What's going on? Any advice/troubleshooting tips are appreciated.
- Motor with pump mounting plate installed
- Sling ring
- Seal plate
- Shaft seal (white part)
- Shaft seal (carbon ring - with carbon ring mating with white part)
- Large washer
- Impeller (no screw or nut securing back of impeller)
- Pump housing gasket
- Main body of pump housing and connector ring
