So I've got more iron stains this year. Vitamin C tablets take it off like magic. Apparently our city water supply has iron in it now somehow. After reading on these forums for awhile, I decided to try and lower the pH from 7.6 to 7.2 and see if the stains get better. I'll keep an eye on it for a day or two to see. I figured I'll probably need a sequestrant, so I went to the pool store and got a couple bottles of ProTeam Metal Magic. So for those of you in the know, I have questions.
1. - It says to get the pH to 7.5 or higher. This seems counter-intuitive but I will raise the pH back up if needed. Should I raise it back up?
2. - I understand why it wants the FC to be below 3 ppm, due to chlorine breaking down the sequestrant. Here's the rub - my CYA is 60-70 right now so I maintain FC above 5 ppm. Will letting it drop to 3 for 48 hours cause other issues? Especially since you're not supposed to shock for a week after using it?
3. Should I take a swim with a sock full of Vitamin C and rub off as much of the stains as possible prior to adding the Metal Magic?
4. Instructions say to "operate the filter system for 48 hours". I've read other places that you should just put it on circulate - should it be in filter mode or circulate?
Thanks!!!
Thanks!!!
