- Jun 22, 2018
- 83
- Vinyl
- Pentair Intellichlor IC-40
Hello everyone, been awhile since I've posted. Every spring I have brown staining on my white fiberglass steps that I remove with vitamin C tablets. I also had staining on my vinyl liner and this year I tried the vitamin C on a small area, and it removed the stain. So I rigged a sock on an old vacuum head and filled it with vitamin C tablets and over a period of a few days got rid of the staining throughout the pool. Looks great. Fast forward to early this week and I had algae pop up, evidenced by lower CL and daily buildup of dead algae on the bottom of the pool. Water was perfectly clear however.
I began a SLAM, target CL was 28 based on my CYA (see pre-slam data below). I've kept up the SLAM for four days now and the water is absolutely beautiful, no dead algae, no CC, but I'm still losing CL on the overnight test (last night went from 29 to 25). I'm stumped and running out of chlorine. My question is could the dissolved iron and/or the dissolved vitamin C be consuming my CL? I've seen old posts about ascorbic acid treatments and how ascorbic will consume CL, and I'm wondering if that could be the issue. I used about three bottles of 1,000 mg vitamin c during the whole stain removal, probably around 750 tablets total. That sounds crazy now that I've typed it out!
Pre-SLAM data:
CL 6.5
CC 0
pH 7.2
Alk 70
CYA 70
CH 50
Thanks for any help!
Pre-SLAM data:
CL 6.5
CC 0
pH 7.2
Alk 70
CYA 70
CH 50
