So the electrician will be out early next week to do the final electrical work. They said one of the ladies will do a 2 hour orientation late next week. Then we can swim. I feel like and I don't know this for sure but they are going to let the water sit until then??? The PB told me the water will be fine, it won't turn green... I'm skeptical...
When it's full can I put in a submersible pump? I have a pentek filter and I'd like to start circulating the water & putting chems in. They told me not to put the pump in. Is it because the vermiculite isn't set yet?
Am I being too impatient or can I let the water sit for that long?
The pool krete website says no one in the pool for 2 days to let the bottom harden otherwise there might be indentations. Ok so I could safely put a pump in there this weekend and get the water circulating & chems going...
Ok here we go. Since the pool is somewhat half full, I logged a 10k gallon pool targeting 40 cya. Pool Math tells me I need 3lbs 5oz. So I'm going to go put 3lbs in a sock and tie it to a noodle. BRB!
