Hello TFP group! Just finished a home purchase with an 11,000 gallon in ground chlorine plaster pool and did my first test run. It has been "professionally" maintained to this point so looking for help getting rolling quickly on TFP's methods. Test kit is a Taylor k-2006c!
FC: 4ppm
CC: 0.4ppm
PH: 8.0
Acid drop test: 2 drops to 7.6 and 3 drops to 7.4
TA: 100
CH: 250
CYA: Very Low (plaster refinished this winter and water completely replaced in the process) possibly around 15?
Besides liquid chlorine (have 30# of tablets remaining as well), what other chemicals do you recommend I stockpile? What would be a good method to start addressing the pool readings above and slowly improvement them?
Will be doing lots of reading but wanted to get everyone's take. Also, the pool has a 15 YO SWG that was "struck by lightening a long time ago" and never put back in service. The panel has various readouts so it is still powered it appears, wondering if the cartridge (turbo cell T-15) is all that needs replaced? Any recommendations on diagnosing and if I should just jump straight into repair of this unit or continue my path with the liquid bleach while I learn to fine tune?
FC: 4ppm
CC: 0.4ppm
PH: 8.0
TA: 100
CH: 250
