My Intex ECO5110/26667EG (up to 7000g) SWG has been installed for about 3-4 months. It's undersized for my pool but was doing the job fine at 6-8 hours a day runtime keeping my pool crystal clear until it wasn't and I dealt with my first SLAM using 4 gallons of bleach from cloudy water (assume algae).
I've tested my Salt with a Taylor K2006-SALT test kit and it registers 3400PPM and I validated with Salt test strips which read about 3150.
So, I will say my Taylor test kit was registering 3800ppm previously when it was working but I disregarded the results because I was new to testing and the salt test is particularly sensitive to the water volume for the test.
Additional info, when the relay kicks on, the titanium electrode plug registers 13v output and 11.5v when connected to the electrode running (not fully seated so I can put probes on the plate posts).
The ECO plate plug is registering 14v when unplugged and like 5v when plug is backed off enough to touch posts with probes.
Thoughts? I don't really want to add salt at this point, my ladder is already rusting big time!!!
So, can I assume the plates are bad and which one? I have searched and can't find a definitive on which voltage the control board uses for "low salt" voltage. The ECO has the bigger drop in voltage but I have no idea if it's really important to chlorine production or this error.
Lastly, unfortunately I did try cleaning per the manual with straight cooking vinegar poured into the electrode tube and sat for an hour. It wasn't until AFTER I cleaned it that I ever saw the low salt error, only reason I cleaned it was because I didn't think it was working since my FC was always low (probably from the cloudy/algae water?). I never saw an error before turning it off for the SLAM!
