Hello ya'll, new forum member/ new pool owner. Got the Intex 24'x12' set up and filled on April 9th. After 3 days I had to backwash the manual said frequent backwashing may be needed when 1st stetting up. Since Monday 4/17 I've had to backwash daily! I have the pump set to run for 8 hrs, after 4 hrs my water jet pressure drops and my psi is in the yellow. It's the drop in water pressure that concerns me cause then the skimmer isn't skimming and the water isn't being filtered. It's been very windy here and lots of dust in the air, I'm in the country and lots of bugs! I vacuum/ remove the bugs daily, the amount of giant mosquitos, gnats and moths I've been removing is mind blowing! We are under water restrictions here and well backwashing daily is gonna be an issue. Should I get a bigger filter that can handle the windy TX dust? Can you point me in the right direction? There is so much information out there and I'm just so overwhelmed trying to figure out what needs to be done. Is it even the dust/ gnats causing the issue?
