Welcome to the forum.Split by moderator from HERE. jblizzle
I have the same problem. Will moving the return to the end and aiming it across the pool help? I want a fountain too. Anyone know of one for Intex pools? Stupid fittings are a pain!!!!
I agree with domct203 and replace that return with a better fitting.
You'll then have an industry standard for any accessory you might want.
You can aim the eyeball towards the wall and slightly downward.
Causing a virtual whirlpool in your pool. No doubt that water is circulating.
Just look for Hayward SP1023 and SP1419D.
Amazon.com : Hayward SP1023 1-1/2-Inch FIP Inlet Return Fitting with Locknut and Gasket : Swimming Pool Safety Products : Patio, Lawn Garden
Amazon.com : Hayward SP1419D White 3/4-Inch Opening Hydrostream Directional Flow Inlet Fitting with 1-1/2-Inch MIP Thread : Swimming Pool Safety Products : Patio, Lawn Garden
Here it is installed in my pool.
It will fit the standard plumbing for both Intex and Coleman(Bestway) pools.
I had to put in a second rubber gasket. Otherwise it wouldn't tighten up enough to prevent leakage. With the second gasket, it's fine.
