TFP Friends - I think the key question I have here is whether my black dot has disappeared (see picture below)... I have other sub-questions I would love to hear feedback on.
If that dot has disappeared, then I'd say my CYA is around 40, which I believe is too low and might explain how much chlorine I'm having to add daily.
If it hasn't disappeared, my CYA is even lower than 40, in which case I definitely need to add more
I can still see the dot, both in real life, and in that picture above.
MAYBe I should have considered the dot to have disappeared much earlier in the test, and my levels are TOO high now (this is what its starting to feel like with the increasing amount of chlorine I'm adding to maintain levels).
SOOO, "How much does that dot really disappear?"
Footnotes:
I'm having a hard time understanding that I can still be this low given how much pure CYA I have deliberately added this year, in addition to running trichlor pucks in my chlorinator. Two summers ago my levels seemed to go WAY too high (according to the pool store... I started using a proper test kit this season), and I had to drain 18inches of water to fix it. The only explanation I have for why they skyrocketed is that I stuffed a bunch of pucks left outside over winter from the previous season into the chlorinator and cranked it up to 2x/3x what I normally run it at (yes, I know this was a dumb move).... but I caught onto the high CYA level within a few weeks. I can't reconcile the things I did 2 seasons ago to get a really high CYA level, with the things I've done this season that results in a really low level. I would think I've done more to increase CYA this season than I did 2 years ago, but the results are inverted?!?! Could the answer be that I actually DIDn't have a CYA problem 2 years ago, and the pool store test results are really that off? 2 years ago I was also having to dump a lot of chlorine in to maintain levels, which corroborates the pool store claim. Or maybe the answer is that I am already too high, and I'm not interpreting the CYA test correctly.
I'm adding about 1.5L of 12% Bleach every day now (up to the last few weeks I seemed to get away with 1.2L and still have FC==1.2 twenty four hours later... 2 months ago I was only adding 0.9L). Maybe the rain, and splashing, etc. has actually diluted my CYA? Or maybe I'm too high?
The Trichlor pucks don't seem to dissolve that quickly. **IF** my CYA is still. low, maybe I need to turn up the chlorinator? I'm running it around 2-4, which has been my "go to" range since getting the pool, but in the early days of caring for the pool it seemed like I added pucks much more frequently.
Footnotes:
