My main pool pump, when on spa infloor cleaner mode, stays on but will stop/restart every minute or so. I measured the 24v relay voltage, and it drops to about 18.
The same main pool pump when put on regular pool pump mode will turn off after a few minutes and not restart. The 24v relay voltage goes down to zero when this happens.
I already replaced the pump with a new one. I swapped relays (between main and secondary pump which does spa waterfall), which will cause the pump to work again periodically, but then the stopping comes back every few weeks.
Do I have a bad board? Bad firmware? Help! This driving me bananas.
