Having an issue with a Intermax PX100, 3 wires on the supply side (14 gauge wires), Black, Yellow, White. 3 Wire 120 supply (12 gauge wires), Black, White, Ground. Hooked Black to Black, White to White, Yellow (capped off), ground from supply attached to ground block.
After connection, applied power, and got 4 volts from one of the output wires (black wire) and 2 volts from the other. Then the transformer started getting hot and smoking!
Have I hooked something up incorrectly or could there be an issue with the transformer?
