- Jun 22, 2018
- 85
- Vinyl
- Pentair Intellichlor IC-40
I've been investigating running my main pump at less-than-24-hrs a day with my Pentair IC-40 SWCG. I had assumed that I could just set the Intermatic timer and that the pump and the IC-40 were connected thru the timer. This weekend I got my SWCG ready for the season and hooked it up today. To my dismay I discovered that the Intermatic timer only controls the pump, not the SWCG. So to summarize, when the pump shuts off via the timer, the SWCG still has power, which I know is not acceptable. I took a look at the wiring in the Intermatic timer box and I have added a photo. In the photo the main power is coming up on the left side, and the wiring to the pump is coming up on the right. You will notice the extra wiring for the freeze protection coming in from the left. Also note that the pump and the SWCG power unit are connected to the same breaker (30 or 50A). To have the pump and the SWCG operate at the same time, I was wondering if I could either just add the wiring for the SWCG power unit and "stack" the wire leads on the timer terminals, or maybe run jumpers from the timer terminals and connect the pump and SWCG power unit together to the jumpers. I know the pump is wired 230 and I'm guessing that the IC-40 power unit is too, since they are off the same breaker? Thoughts/advice/warnings?
