Hey... so the timer on my pump bit the dust this past week after only having been installed for a few months. It was a relatively cheap digital timer from Home Depot that was 120V, 240V, 277V selectable, and when I went to leave a review for it it had already been discontinued, haha. So I decided to just order what had originally been installed when I bought the place, which was a T103 Intermatic. However, when I went to install it, I realized it had a neutral, and checking... yup, it's supposed to be wired at 120V and naturally the wires leading to where my pump is installed are wired for 240V with no neutral wire, only two hots and a ground. Now I'll be honest, I know next to nothing about electrical wiring... only enough to be dangerous. So it's possible I'm just not understanding something. But I'm guessing the previous owner had either replaced the motor with something 240v capable but kept the T103 shell, or had run the ground to neutral, right?
So what should I do now? Grumble and buy a 240V capable timer? Ground to neutral? When I install it without the neutral (keeping the ground grounded), the clock predictably doesn't work, however the manual on switch does start the pump. Would this be more or less dangerous than grounding to neutral if I have to replace it and need to wait for a new motor to arrive (mid-summer in Arizona already started to turn the pool green without the filter running for a few days)? Like I said... I know just enough to be stupid so I want to feel out my best (e.g. cheapest) option that won't (likely) set my house on fire. Thanks!
For reference, the currently (incorrectly) wired T103:
https://postimg.cc/image/ewbzh3793/
