I have what I believe to be a 158T8454 timer (that's the only number I saw on the box....not sure if it's the correct one since googling doesn't show the same picture)
The timer motor is working as I can hear it clicking and it rotates during the day, but when it becomes time to actually turn ON the pump, it seems to jam and not have the torque to actually turn the timer and trigger it on.I can go out several hours later, and the dial is stuck at JUST before the time to turn on, and if I give it a little turn, the timer works fine for 24 hours. In the photo you can see the timer should have turned on around 6 AM. I took the photo around 8AM, after having set the time correctly yesterday....so it was just stuck at 6 AM - I continued to hear it ticking though.
I have tried different start times and I get the same issue, so I don't think its that specific half hour increment pin that is causing the problem.
Additionally, this was a problem a couple months ago for a few days, then stopped happening. It just started again a couple days ago so I assume it's not going away. I have to walk out to my pad every day to turn on the pump at this point.
Any thoughts on what might be happening? Can anyone point me to the true model of this unit so if I need replacement parts or a new unit I can find it?
Thanks!
Thanks!
