Can you buy just the clock motor instead of the whole PF1102MT mechanism?
I have this model (240v) on my pool that includes the freeze protection. The clock motor gear will not turn AND I do not know if the gear is even supposed to turn freely without power. It was working fine until the hard and long freeze here in Fort Worth. Lost power for a couple of days and things froze up. Had to replace some above ground plumbing. When I fired everything back up the clock wasn't working. I can still spin the timer with the on/off tabs and the manual knob all still work to turn the pump on/off. I see other clock motors that look very similar but do not have the same part number (WG1773: 208/277v 60HZ). So my roughly $200 question is: can I buy just the clock motor by itself and save some $$$.
Would appreciate any info on this.
Thanks
Thanks
