When I connect timer to outside outlet, the indoor GFIC outlet trips. Done the following:
1. Removed timer from outside, unplugged kitchen appliances inside, and reset indoor GFIC, - Results - Red button stays pushed in.
2. When connect timer to outside outlet, then GFIC red buttons pushes out and will not reset.
3. Go to fusebox, reset circuit breakers, everything is fine, except when I connect timer.
Is this due to a faulty GFIC outlet or some other issue?
If you need further information or photos please let me know.
Thank you for your time.
