Moved from here... Intermatic Multiwave PE653rc + AquaRite goldline swg
It's been a few years since this question was posed. Does anyone know if Intermatic has documented the RS485 loop with the AquaRite via the PE635RC?
On the AquaRite:
GREEN = Ground
YELLOW = -DT
BLACK = +DT
RED = +15
I'm still figuring out how exactly my PE635RC will control the AquaRite. I do see in the AquaRite installation manual they do propose hooking up the AquaRite 240V on the same 240V circuit the pump is running on. However, since mine is an Intelliflo VS the fact that it is energized does not necessarily mean the pump is running. Hmmm, will have to noodle on this a bit more.
On the AquaRite:
GREEN = Ground
YELLOW = -DT
BLACK = +DT
RED = +15
