Hello!
I have an Intellicenter panel connected to an intellivalve on the “Valve A” connection on the control panel. It diverts water to the cleaning system or the water feature in my pool.
This valve has worked great for a year, but recently when I turn on the water feature circuit, the valve appears to just turn off (all lights on the valve go dark). If I shut the ”water feature” circuit off, the valve comes back on. I find this very odd as I was under the assumption that toggling the “water feature” feature circuit would move the valve from the home position to the other set position (which I believe I have set correctly on the value).
Is this some sort of power malfunction? I can’t see anywhere in the Intellicenter portal where I could modify this behavoir and just wanted to check here before I paid someone to come out and have a look at it.
