I have added the automated bypass to my master temp and intellitouch controlled Pentair system.
While everything works well when heat is called for: ie the bypass valve activates and starts allowing water to flow to the heater before the heater starts, when the temp is reached or the intellitouch turns off the heater , the heater starts its cooldown and then the intellitouch removes power from the heater before the heater is able to reset the bypass valve.
Is there any way to increase the delay time for the heater to cooldown before power is disconnected?
