I have the Pentair EasyTouch controller and use the ScreenLogic iOS app as my main interface. I've set my pool up to run for roughly 9 hours per day but in the middle of that I turn the spillway from the spa on at 3 different times just to move the water in the spa. I could SWEAR when I originally set this up all 3 waterfall schedules worked fine (morning, noon, and early evening). However, after messing with the schedules and then trying to set them back to the way they originally were, they don't all work. Originally my noon waterfall period stopped turning on but the morning and evening would. I turned the breakers off and restarted the whole system and voila, the morning and noon waterfalls work, but now the evening won't. I've let the system run for more than 24 hours, thinking it may be a timer/cycle issue, but tonight was 48 hours and the evening waterfall didn't work again.
Has anybody else experienced this problem? My scheduled run tines include regular filtration, suction side cleaner, and the 3 waterfall periods. There are never more than 2 schedules that overlap (e.g., the filtration timer is running and then the waterfall kicks in for 30 minutes during the time period. The cleaner period, with a higher pump rpm speed, comes later).
Not sure how to fix this seemingly simple issue.
TIA,
Fred
TIA,
Fred
