I have a 14 yr old system that is driving me crazy. it started out with a bad spa side switch that i took off the system. I cant set the time and i have no water temp reading and air shows 0 degrees. I swapped temp sensors-no change. i have a indoor panel, old mobiletouch handheld, and a new wifi device-unsure of name. i have made a small jumper wire for the indoor panel to eliminate a bad wire run, so that i can sit at equip. and use the indoor panel. yes, i swap the mobile touch antenna/board and wifi board when i use that item. i get a error retrieving data on all devices. i have talked to pentair - was told to replace boards, did that and no change. talked to pool builder/friend and he gave me 2 used boards-no change. i have installed 2 new boards-no change. last 2 new boards i have only installed temp sensor wires to see if something was taking out boards-no change. is my indoor panel bad? and taking out boards? thanks jim
