Intellitouch - Pool Heat Schedules
skavan
Aug 28, 2015
14
Connecticut
Hi,
Apologies for poor terminology in advance!
I have a pool/spa controlled by a i10 3d.
The pool (it's big) has two pumps and MasterTemp 400 heater.
I think I have set the pump rpms to run at one speed for circulation and another for heating.
Now to the question:
  1. I think I have scheduled the "Pool" to turn on at 5:00am and run to 2:00am. As best as I can tell, this doesn't turn on the pool heat (which is good).
  2. I want to schedule the Pool heat to run from 6:00am to 6:00pm. But I can't figure out how! On the Menu/Progra/Select screen, there is no option for Pool Heat. On the Menu/Program/Pool page, there is no option to add "Heat" to a schedule. I'm missing something. Could someone kick me in the right direction please.
Thanks in advance.
s.
Well - yes and no!
I do. But whenever I plug the screenlogic brick in, the Intellitouch system goes crazy and starts reportiing pool temps that are crazy low (45 degrees) or sometimes crazy high (125 degrees). I swapped in a spare Intellitouch brick, with the same results. So am thinking there is something screwed up with the ethernet wiring that runs to the house.
so - am trying to set this up without screenlogic...driving me crazy.
sk,
With ScreenLogic on your PC you get the following scheduling page.. If you look at my spa schedule you can see that it is possible to set up the heater to come on at a particular time at a particular temperature.
Maybe you can use my schedule as an example, and then set it up manually via your remote.
Notice the three heater options that need to be set in the lower right of the screen.
Jim R.
hey guys, apologies but I don't have a heater so I don't really know how to set them up. My only suggestion would be to see if there's something in the intellitouch manual.
sk,
Jim R.
Thanks Jim,
See my note about Screenlogic adapter! My question becomes how do I set those settings in the remote panel (outsie of Screenlogic): Heat Settings etc...
s.
