Hi
I have an IntelliTouch and a master temp. At some point recently my master temp refuses to 'listen' to the IntelliTouch control. Reading through TFP I see that it is a fireman's switch that controls the mastertemp.
I have set the master temp to 104 like others have suggested, but the master temp refuses to turn off when the set point is reached on the Intellitouch.
I have since pulled the 2 wire connector off the Intellitouch which turns off the Mastertemp. Plugging it back in, the master temp turns on and calls for heat (even when the Intellitouch is not calling for it.)
I'm looking for any advice. Does the address of the MT unit matter? I've tried address 1 and 2 but nothing seemed to change.
Attaching a couple of pictures of the setup.
You can see that the circuit labeled gas heater is NOT on, the master temp is still heating and the controller is not calling for heat either.
Any suggestions are welcome!
Thanks
Joe
Thanks
Joe
