Pool pumps did not run yesterday so I went to check out what it might be, finding the low voltage circuit breaker tripped for the relays.
Reset it and it tripped again.
Checked & tested breakers and found the Main Filter Pump breaker would not trip when I pushed the ground fault test button. So that is the 1st part I need.
Did not explain the low voltage issue.
Tried switching two of the low voltage circuit breakers to see if it was bad. It was not, the breaker I switched to tripped the same.
I suspect my Transformer might be toast. We had a pretty bad electrical storm a couple of days back. It was working afterwards, but it may have taken a surge.
My transformer model is a Pentair 521082.
I noticed in an old 2018 thread someone had to replace one of these and the replacement ended up being a different part number.
The replacement part number was never mentioned.
Any suggestions on locating the 'right' replacement? I have found a Pentair 521233 that 'looks' like the one, but it does not have anything that says it is a replacement for my part.
Odd think is when I zoom in on the picture of the listing it has my part number on the transformer. (link attached)
www.poolzoom.com
PoolZoom - Pool Supplies & Parts
Shop the best pool parts and supplies at PoolZoom. Quick shipping and huge in-stock inventory!
