Sorry, I've been out of town for a couple of days.
It sounds to me like your pump is being powered by the Pump/Filter relay, which is wrong.
It does not sound like you are using the RS-485 cable to control your pump.
It could be your system is so old that it will not support the RS-485 pump control.
Go out and drop down the front panel and see if you can find a label with the Firmware Information on it and tell us what it says..
Let's see if Tom,
@ogdento, knows if the early version IntelliTouch units could control VS pumps or not.
I assume you have never seen your display show "Display Not Active"??? Is this true?
Does your VS pump have a small cable plugged into the side of the pump's control head?
Show us some pics of the pump and the outside IntelliTouch board.
tell us the firmware version of your Intellitouch system... go to Menu > Setup > Advanced, then press buttons 2 and 4 along the bottom and the top option is to show the software revisions (check the Intellitouch manual if my steps don't make sense).
Also, what pump do you have... your profile says 3HP Pentair VSP. If it's an Intelliflo it should be powered on all the time and a comm cable connects to the outdoor board which tells it when to turn on and off.
