My local Pentair authorized installer just installed my new Intellipro VSF in a way that seems contrary to the instructions in the manual.
There are 2 issues: The suction inlet pipe is much shorter than recommended and there are elbows very close to although not directly connected to the inlets and outlets, all of which are contrary to the installation instructions.
The manual states in, "“We also recommend a valve, elbow or tee installed in the suction line should be no closer to the front of the pump than five (5) times the suction line pipe diameter. See Figure 2.
Example: A 2-inch pipe requires a 10-inch (254 mm) straight run in front of the suction inlet of the pump). This will help the pump prime faster and last longer. Note: DO NOT install 90° elbows directly into the pump inlet and outlet."
In my case, the suction inlet pipe length is just the few inches you see in the photo (only the length of the connection) AND there appear to be elbows almost directly installed at both the inlet and outlet.
It sounds like there wasn't enough room on my pad to begin with, but I am not sure if my assessment is correct and, if so, how detrimental the effect? Should I request they reinstall it? I expect this pump to run at least 10 years. Is it OK to run the pump "as is" until then?
