Probably me thinking in spanish and translating is not working very well. What i meant is the current draw! I understand that is does not switch. Current (amps)would flow on the red when in normal polarity and more through the black when in reversed polarity. Remember an MD trying to understand electricity!
Gotcha. No, it wouldn't work that way. The current that is traveling through the IpH would likely be identical regardless of the polarity on the IntelliChlor plates. Regardless, even if the IC draws slightly more current when the IC plates are in "+" mode or "–" mode, the current through the IpH's wires would be identical. Put another way, whether the IC is on or off, or producing chlorine or not, or reversing polarity this way or that, whatever amount of current running though any of the four power leads in the IpH (the two reds and two blacks), whether it's zero amps, or 10 or 9.9, whatever, is also running in the other three power leads. The amount of current does vary, depending on what the IC is doing, but all four wires each carry the same amount at any given point in time.
Think of it like the pipes in your pool's plumbing. Flow (like electrical current) is constant throughout it's path. Whether the pump is on high, or low, or medium, the
amount of water running through the pipe feeding your pump is the same amount coming out of the pump, or out of the filter, or through your SWG. At whatever point you measured flow, it would be the same. If it's 5 GPM going into the pump, there will be 5 GPM coming out. And 5 GPM coming out of your filter, 5 GPM flowing back to the pool. If the pump RPMs increase, and the pressure increases, so that the pump is now drawing 10 GPM out of the pool, you'll be getting 10 GPM everywhere else, too.
Electricity works the same way. Even if the electrons are routing this way and that within a circuit board, whatever amount goes in through the black wire, comes out through the red.* Even if there is energy loss within the board, like heat dissipation from a resistor, or an LED emitting its energy via light and heat, the current going into the board would be measuring the same as the current coming out.
*Just for giggles: what's
actually happening is the molecules in the wire are exchanging electrons. They jump from molecule to molecule, along the wire. If you push on one electron at one end of a wire, it'll jump to the next molecule, and push one electron out of that molecule to its neighbor. And so on, all the way to the other end of the wire. The first one that got pushed doesn't speed through wire and pop out the other end at the same time, that'd be a different electron. Eventually it'll make its way out, but not immediately. Like if you push a cup of water into a pipe full of water. A cup will come out the other end, but not that original cup. It'll get there, if you keep adding more cups of water, but it'll be some time later.
That effect, of pushing on an electron at one end to have another pop out at the other, happens at the speed of light (or thereabouts). That speed is constant. How much pushing is going on is like water pressure. That's voltage. How many electrons move from the pushing is current, like water flow.
Contrary to intuition, the push starts at the negative end. The electrons move from the negative side to the positive end.
That's all greatly simplified, of course, but that's the gist of it...
