Well my son tried to help me out and clean the pool cartridges. When he put the system back together he didn't put the clamp on the filter body correctly and sometime that evening the top of the cartridge body was launched 30' into the yard. Yesterday evening I put everything back together and tried to start the pool pump (Intelliflow variable speed pump) and it will not start. The control panel on top of the pump is blank. I checked the breakers and power is on. The pump had run for a period when to filter top blew off because the water in the pool was 12-18 inches below the tile.
Any thoughts on what might be the issue with the pump ? Thanks in advance for your thoughts.
