- Jan 12, 2024
- 23
- Plaster
- Pentair Intellichlor IC-40
Hi,
I bought a house with a pool back in Feb., and had a heater and control system added to it. The current system has: Intelliflo VSF (3.95 THP), Clean & Clear Plus 320 sq ft filter, MasterTemp 400 heater, IC40 SWG, Intellicenter i8PSIC40.
I see that the IC40 requires 20 gpm (+/- 5 gpm) to function and the MasterTemp owners manual lists a minimum of 40 gpm and maximum of 120 gpm for the 400 model. My pool is about 20,000 gallons. The equipment pad is less than 10 feet away and the ground is pretty flat.
These are the flow rates according to the Intelliflo that I am getting:
Do these seem really bad? The SWG gives a flow error until I reach about 2100 RPM, so that flow rate seems in line with what the pump is saying.
The pool builder checked the filter and said it was clean and that the PSI seeemed normal. I think the PSI was about 12 at 2000 rpm and maybe 20 at 3000 rpm, but I could be remembering wrong.
It seems strange that it has to be nearly 500W just to run the SWG, which I was intending to just leave running all the time.
RPM | GPM | Watts |
2000 | 14 | 323 |
2300 | 21 | 508 |
3000 | 39 | 1192 |
3200 | 45 | 1479 |
3450 | 54 | 1897 |
