Intelliflo VS keypad replacement
PALarry
1
Palo Alto, CA
My Intelliflo Variable Speed pump will not hold time settings during a short power outage (2 hour is so). It is a 2014 vintage pump, with security Torx screws on the keypad assembly. I bought a replacement keypad assembly (357572Z), but after removing the security Torx screws, I have been unable to pry the old one off the motor. My installation manual replacement parts diagram doesn't show the keypad as a separate item, but as part of 353251 VS drive assembly.
Is this replacement keypad supposed to fit this unit? If yes, how should I remove the old keypad assembly?
