- Sep 17, 2022
- 83
- Plaster
- Hayward Aqua Rite (T-9)
TFP fam,
Asking for a friend of mine. They moved into a new property with pool where the schedules and pump/filter system were all working fine until the new pool maintenance guy manually started the pump when chlorinating the pool.
Since then, irrespective of the schedules the pump doesn’t start. The filter pump button on easy touch panel turns on and off per schedules but the pump is not starting unless it’s manually turned on.
We tried resetting the pump settings in Easy touch control panel, cut off and restarted the pump, reset the pump by holding the 4 speed buttons for 4 seconds and restarted the pump. And no luck yet.
PFA the pics for reference:
1. When pump is running.
2. Easy touch panel.
3. When pump is not running.
4. Overall filter system.
