Jeff,
No not really... It makes perfect sense to not buy the IntelliFlo, if the goal is to not spend the extra bucks... But your idea that you can't use the IntelliFlo because the pool is too small does not make sense.. One of the mods here has an IntelliFlo and I believe his pool is only 6K...
The larger the pump the slower you can run it and still move the same about of water..
There are a couple of reason to own a VS pump... Cost of electricity, very quiet, and in my mind the most important reason is to change speeds to meet your pools requirements..
I'll use my pool for reference... I run at 1200 RPM, to move enough water to turn on my flow switch.. At that speed, the pump uses about 180 watts of power.. Then a few times a day the pump ramps up to 1500 to help with skimming.. When I turn on my waterfall the pump ramps up to 2800, because it takes more flow to make the waterfall work.. All this happens automatically via my automation system.
The Pentair SuperFlo VS could do the same job, but it would have to run faster to produce the same amount to flow, and the SuperFlo VS is not directly controllable via my EasyTouch automation system.
If the pool does not have an automation system nor any water features, then to me, a 2-speed pump is a better option that a VS pump.
Sorry, maybe I still don't understand your point of view..
