Hi there,
I've been having an issue with my pump not priming for some time. At low RPM's the pump stays primed, but anything above 2000 RPM's causes the pump to quickly lose prime. I've tried troubleshooting all standard culprits, drain plug, skimmer, o-ring, pump lid, impeller, with no luck. My original worry was a suction side leak, but after having a few technicians out they don't believe that is the culprit.
Most recently, a technician changed the location of the temperature sensor from the suction side to the pressure side, which did not work. He mentioned it might be the filter causing a backup, because the filter is old. However, I purchased a new filter and replaced the old and still having the issue. Now the company is saying it might be that there is a buildup in the pipes, and they are asking to come back out to blow out the pipes. BeforeI spend more money on a service visit again however, I want to make sure that is a viable potential solution. I've been spinning my wheels for months now and have not been able to resolve this.
Any insight is appreciated. Thank you!!
