Note: Maximum Speed will limit Priming Speed, except in one case.
If the Maximum Speed is set below the lowest available Priming Speed (2400 RPM) then the pump will exceed the Maximum Speed while the priming feature is running.
This prevents the pump from having trouble priming if the Maximum Speed is set this low.
If this is a problem, priming can be disabled in the Priming Menu (see “Priming” section on page 17).
Set Maximum Speed (RPM)
The maximum speed can be set from 1900 RPM to 3450 RPM (default is 3450).
Use this setting to set the maximum running speed of the IntelliFlo® VSF Variable Speed and Flow Pump.
Note: Maximum and minimum speed settings, and the associated alarms, remain active when in Flow mode.
1. Check that the green power LED is on.
2. Press Menu.
3. Press Select to select “Settings”.
4. Use the Up or Down arrows to scroll to “Min/Max”.
Press Select.
5. Use the Up or Down arrows to scroll to “Set Max Spd”.
6. Press Select to change. The cursor will appear in the first number column (ones).
7. Press Up or Down arrows to edit the maximum speed
setting from 1900 to 3450 RPM.
8. Press Save to save. Press Back to exit. To cancel, press the Back to exit without saving.
Pump Menu: Priming
The default setting for Priming is ENABLED.
This setting allows the pump to automatically detect if it is primed for startup.
The priming feature increases the pump speed to 1800 RPM and pauses for three (3) seconds.
If there is sufficient water flow in the pump basket, the pump will go out of priming mode and run its commanded speed.
If the water flow is not sufficient, the pump speed will increase to the “Priming Speed” setting and remain for the priming delay time (default 20 seconds).
If there is sufficient water flow in the pump basket at this time, it will exit priming mode and transition to the commanded speed.
If there is still insufficient flow in the pump basket, as determined by the Priming Range setting, the pump will try to prime at the “Priming Speed” for the amount of time set in the “Maximum Priming Time” menu.
Once the pump achieves prime, it will resume normal operation after the preset priming delay.
