Intelliflo and Intellicenter
illiterate101
1
Wichita
I’ve got a brand new pool, but am on my third builder now and am piecing stuff together. When the electrician wired my pump, it works and turns on but doesn’t work through the automation. It appears as though I need to move the wiring from the filter spot to the J4/J5, issue is I don’t seem to have a green/yellow wire anywhere. Is that something separate or something I need to buy? Assume it was probably in the box and got thrown away.
Just trying to make everything work, guy who finished the pool is a legit worker, but old school so all the automation stuff makes him scratch his head and his son who was supposed to set it up has been slow at best.
101,
The RS-485 cable comes with the standard IntelliFlo pumps.. If you have the new IntelliFlo3, the cable has to be hand made..
You can buy a new RS-485 cable for $$$
All VS pumps should get constant AC power.. They are not wired to the Load side of the Pump/Filter relay. If your is.. you can just move the wires over to the Line side of the Pump/Filter relay. But, when you do, the pump can not be controlled by the IntelliCenter unless you have the RS-485 cable connected to the com port inside the IC.
