We built our pool in very early 2017, it was filled on Valentine's Day. In the summer of 2020, I noticed dampness under the pump which was attributed to a leaking shaft seal. By the time the new shaft seal arrived, the leak had stopped and I didn't think it was worth tearing into the pump to replace the seal since the leak had stopped. Fast forward to this morning when I noticed a wetness under the pump and saw a healthy level of corrosion about the motor where it mounts to the pump body. In hindsight, I should have replaced the shaft seal back in 2020. I can do that now. Is it worth trying to replace the motor, or just bite the bullet and get a whole new pump? If the new pump is the recommended direction, stick with the 3HP model or could I go down to the 1.5 HP model? We are currently run the pump at 1600 rpm, every when we turn on the water fall and bubblers. Thanks in advance!
