Marty,
The OP has an IntelliConnect, not the IntelliCenter.. It works differently than every other Pentair automation system ever made.. It does not shut the power off the SWCG, it just somehow prevents it from generating chlorine..
Sagosto,
You would think that since the cell should not be allowed to generate chlorine when the pump is off, you should get that warning every time the pump is off not just some times...
We talked about this before.. I said you have to use one of the relays to turn the cell off, but you pointed out that the manual says you do not have to use a relay, that the IntelliConnect controls the chlorine production when the pump is off...
