I noticed since we installed a VSP (two years ago), our Intellichor IC40 output has been kinda milky looking. I hadn't thought much about it while the water was clear figuring it was because of running the pump at lower rpm (e.g. 1400) making it visible.
But a few weeks ago, the flow sensor went out and the water became a bit murky. I've since replaced the sensor, but the water quality hasn't improved (I'm working on that). I noticed that sometimes there is what looks like sea foam floating on the water surface, and it is from the chlorine generator.
Any idea what's going on?
