Intellichlor IC 40 Only Steady Green Lights, Even When OFF!
hodapmj
0
54
Arkansas
3 year old Intellichlor IC 40 connected via the 10 year old, Easy Touch. On the Intellichlor, steady green lights for Flow, Salt, Output %, bottomline looks like it is running fine. Diagnostics on the Easy Touch indicate no errors. Here is the wierd part, even when the pool is turned off, it is indicating STEADY green lights like it is running normal! Easy Touch diagnostics says "No Errors"! If I unplug the Intellichlor from the Easy Touch, it STILL says no errors and everything is fine! Any clues as to what's going on?
