I have a Pentair Intellichlor IC40 that burned itself up.
I am pretty sure the failure was from a faulty fuse. The system has one of the push to reset fuses. It was stuck and did not switch to open causing the salt generator to burn a hole in itself.
This happened a few months ago. I kept smelling slight electrical burning in the back yard but thought it was the neighbor.
I have since replaced the fuse and I am getting ready to order a new generator. Is there anything else I should be checking before instal and should I go with the same model? The bad on is from 2015 or 2016.
Thanks in advance.
Thanks in advance.
