Hi all,
Had an issue with my IC40 not showing salt levels on my Easy Touch. Found out through this forum that I have a bad temp sensor that isn't communicating with the easy touch. I'm still generating salt, so no major issues there as I test the salt levels with reagents monthly. While reading posts on the forum searching for an answer, I noticed several strings that said the lights on the IC40 should be off when the pump is off. Mine have always stayed on since I've purchased the house (2 years ago).
Digging into my wiring, I believe what I need to do is move the wiring from the line side to the load side. Also would appear that on my current set up, I need to move the wiring to be on the main pump relay, as it currently sits on Aux 1 (cleaner).
I took a picture and drew a rudimentary wiring diagram after I traced all the wires. Before I move the wires for IC40, I wanted to double check that I'm not going to mess anything else up as my set up has a small secondary box in between the Aux 1 and the transformer connecting.
I'm running a single speed Century pump for my filter, and a smaller Century pump for my Kreepy Krawly cleaner.
