I have an issue - and a question. Right after my multiport filter value there is about 12 inches of straight pipe and then a 3-way value that bypasses the heater. Now .... i notice that when i bypass my heater, my GPM on my VSF pump increases. This makes sense as I’m skipping the heater, and reducing “head?” loss.
OK - here Is the odd part - between the filter and the value there is a water feed that goes into a water sampler for my intellichem. When i run the water through the heater there is plenty of flow to “turn on“ the intellichem magnetic flow sensor.
However, when i turn the value to bypass my heater (which remember produces higher GPM at the same RPM), there isn’t enough flow to activate the intellichem magnetic flow sensor. i disconnected the flow line that goes into the intellichem system, and was able to see a noticeable drop in flow when i bypass my heater with the value.
Only thing I can think of is the 90 degree elbow somewhat limited the flow into the intellichem? Is there a better spot for that in feed? This is also an out feed that is plumbed in before my SWG.
End goal is to replumb the pipes to create a actuator bypass for the heater - don’t use the heater that much and ive noticed tremendous head loss. Issue is that i want to keep the UV light so bypass value on the heater and then go to the UV then to the SWG. Need to repipe some stuff... any ideas? A
