I have an intellicenter and the pool builder setup two modes - pool and spa. When in pool mode water is added to spa and the spa drains are off so that the water overflows from spa to main pool body over spa waterfall.
My question - is there an easy way to have a pool_mode1 where it doesn't add water to the spa so that the waterfall isn't overflowing and just the pool is circulating? I could run the regular pool mode for a while or run the pool_mode1 for a while depending on what I wanted to do. I wouldn't mind running that way to see how it helps the PH over the winter.
Also would like to be able to turn off the waterfall to allow some sealer to dry without water hitting it.
Hope this question makes sense...
