Intellicenter setup
Can you elaborate on your question a little bit more? Are you talking about the SWCG setting? You can set different levels of chlorine production based on if it is in spa or pool. I think generally most people run less chlorine production in the spa as it is a smaller body and it would be more concentrated and 'in your face' than in the pool.
--Jeff
Yes but my spa overflows into my pool when its just in pool mode so assuming that spa mode setting only means something when I am using the spa and have the valves shut off to the rest of the pool?
So my settings have always been like 40% pool and 20% spa but I always wondered if the spa setting could be zero and the 40% for the pool would be flowing through the spa in normal pool/spa mode.
Jeff,
I am not sure you fully understand how the cell's Pool % and Spa% works.
Anytime you are in the Pool mode, and the spa water is spilling over into the pool, your cell is producing chlorine at the Pool %.
The only time the cell would run at the Spa % is when you are in the spa mode and the spillover is shut off.
If you never use the spa, then there is no reason to set the Spa % at all. It can be zero or 50% or 100% it will make no difference unless you are actually in the Spa mode.
Reactions: 4x4tx
