Intellicenter Schedule Question
superskaterxes
3
Maryland
Hi All,
i am having an issue that i cant figure out. My current schedule is as follows:
Pool group is just Pool + Salt generator (on an aux circuit)
sense read is for when i turn the pump speed up to read parameter better with my sense S2
the problem i am having is that when 12:30 comes around, everything shuts off. I have tried to adjust times up or down a minute for some overlap and still no dice. When i go from pool group to sense read, the pump does speed up (meaning whats supposed to happen, does happen), but when it should go back to normal speed at 1230, everything just goes off. What am i missing?
SS,
Are you wanting to shut off the SWCG, when you using your 'S2' ?? (No clue what S2 is... :mrgreen: )
If not, I would schedule Pool Group from 10 am until 7 pm. Leave Sense Read scheduled from 11:30 to 12:30 pm..
The key is that when the pump sees two or more speeds, it will always run the fastest one..
There is just no reason to overlap by 1 minute.
Not sure if that will fix your issue, but worth trying..
Also make sure your egg-timers are set to the default of 12 hours..
Reactions: Turbo1Ton
